08-17-2012 12:41 AM - edited 03-07-2019 08:23 AM
Hello everyone
when I do a show module in my cat 6509, the standby sup is saying unknown, it has the same IOS as the primary card.
what does this mean?
are there any tests I can run on the card?
cheers
Carl
08-17-2012 02:16 AM
Hi Carl, if your IOS matches across the cards then it's likely that your standby supervisor is either stuck in rommon or in a boot loop. You will need console access to recover it if that's the case. Have you tried to reseat it?
08-17-2012 06:59 PM
Card's either faulty or in ROMmon. Console into it to find out further.
