02-07-2012 02:23 PM - edited 03-07-2019 04:47 AM
Need Help...
I have been experiencing issue with POE on several of my switches where for what ever reason the module stopped providing POE to the ports.
I tested POE on five other ports on the module with a Cisco IP phone 7965 and no luck not providing POE. I even tried it with Aruba wireless POE device and I got the samething, no power. I have been expereincing the same issue with two more switches and the only was i was able to resolve the issue was to reset the module. The first time I hard reset the card and fixed the issue, the second time around I did a soft reset and it fixed the issue as well.
I was just wondering if any one has expereinced the same thing and if there is a fix for it.
Thanks, Any help would be greatly appreciated.
Jack.
We are using the following hardware 4507R+E Swtices running IOS ver 12.2(54)SG
sh module
Chassis Type : WS-C4507R+E
Power consumed by backplane : 40 Watts
Mod Ports Card Type Model Serial No.
1 48 10/100/1000BaseT Premium POE E Series WS-X4648-RJ45V+E JAE14340KT0
2 48 10/100/1000BaseT Premium POE E Series WS-X4648-RJ45V+E JAE14340KSZ
3 6 Sup 6L-E 10GE (X2), 1000BaseX (SFP) WS-X45-SUP6L-E JAE143501I4
4 6 Sup 6L-E 10GE (X2), 1000BaseX (SFP) WS-X45-SUP6L-E JAE143500QH
5 48 10/100/1000BaseT Premium POE E Series WS-X4648-RJ45V+E JAE14340TE3
6 48 10/100/1000BaseT Premium POE E Series WS-X4648-RJ45V+E JAE14360BJT
M MAC addresses Hw Fw Sw Status
1 f866.f284.bda0 to f866.f284.bdcf 2.0 Ok
2 f866.f2c8.1590 to f866.f2c8.15bf 2.0 Ok
3 f866.f27e.0040 to f866.f27e.0045 2.0 12.2(44r)SG5 12.2(54)SG Ok
4 f866.f27e.0046 to f866.f27e.004b 2.0 12.2(44r)SG5 12.2(54)SG Ok
5 f866.f2ee.c720 to f866.f2ee.c74f 2.0 Ok
6 d0d0.fdfa.f1e0 to d0d0.fdfa.f20f 2.0 Ok
Mod Redundancy role Operating mode Redundancy status
3 Active Supervisor SSO Active
4 Standby Supervisor SSO Standby hot
nyc-wfcacc41wst3a#
02-08-2012 06:15 AM
Try with power inline static under interface and shut/no shut interface, otherwise module is faulty. you need to raise RMA
02-08-2012 06:19 AM
Thanks for repluying.
what is power inline static do?
02-08-2012 06:35 AM
It define the power for the port instead of auto negotiating and rrquest for power grant.
02-08-2012 06:46 AM
The weird thing with this is when I do show power inline mod 6 command it shows as if there was a POE device connected to g6/48 which there is no device connected to it.
Gi6/48 auto on 16.6 15.4 Ieee PD 0
Totals: 1 on 16.6 15.4
02-08-2012 10:41 PM
Can I recommend something? Can you kindly plug the 7965 DIRECTLY to the switch port? If it lights up, then I have a fairly good idea where the problem is. If it doesn't then I want to ask if you are willing to eliminate a Layer 1 issue.
Before we proceed, I would like to issue a DISCLAIMER. The TDR process for a 4500 is taken from the pages of the 6500. This means that the TDR result for the 4500 is NOT VERY ACCURATE.
Here's how it works:
1. Command: test cable tdr interface Gi 6/48;
2. Wait for about 60 seconds;
3. Command: sh cable tdr interface Gi 6/48;
4. Please post the output.
I know that it takes at least 60 seconds for the TDR of the 4500 to complete (while the cheaper and less powerful 2960/2960G/2960S, 3560G/3560E/3560X and 3750G/3750E/3750X takes only 5-7 seconds).
I await for your result.
