11-25-2006 05:35 PM - edited 03-05-2019 01:01 PM
We have 6006 switch with WS-X6K-SUP1A-2GE and WS-F6K-MSFC2.
Cat OS is 6.4(20)
But I am getting error message
Module Type Unknown Card, Status power-bad.
When module is removed and inserted I have seen console message
APGBIC> (enable) failed to read serial eeprom of linecard in slot 6.
Can I have any suggestions on this?
There is redundant power supply 1330watts.
SKRAO
11-25-2006 10:40 PM
Hi SKRAO,
Which card is giving this error message? Can you post the model number?
I believe the card which is giving this error message is not supported by the image which you are running on your supervisor. Second reason could be that its a bad hardware also.
Just most the model number of card?
Ankur
11-26-2006 03:36 AM
Hi SKRAO,
I have already encountered the similler problem before, This is a Modules Hardware Problem.
Danny
11-26-2006 09:27 AM
Hi Ankur,
Part Model Number is WS-X6324-100FX-MM. Which is supported line card in 6006 with minimum
CatOS 5.3 and recommended 6.4(11)
SKRAO
11-26-2006 09:38 AM
Hi Skrao,
As you already have the supported image on sup remove and reinsert the module which I believe you have already done. If this message appears again, reset the switch.
If the switch is still unable to read the EEPROM, its a bad hardware then.
Ankur
11-26-2006 09:52 AM
Ankur,
Thanks for your reply. I have tried reseating, resetting and placing in another slot. But same result.
Previous card given same problem. This is new module, giving same problem. I don't have spare 6006 to test the module.
SKRAO
11-26-2006 09:57 AM
Hi SKRAO,
Can you try resetting the complete switch if possible?
Also if possible post the "sh mod" , "sh env" and complete error messgae with with % and all.
Ankur
