Monitor module in 7609-S
hi all,
do any1 knows, which command will be used to monitor snmp of module WS-X6748-SFP in 7609-S
i have proper snmp configuration in place but when my module went down, i got no laert in LMS3.0.1, instead i got alerts for access switches connected on that module
any help is appreciated
below is the config....on 7609
snmp-server engineID local xxxxxxxxxxxx
snmp-server group ABCD v3 auth notify *tv.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF7F
snmp-server group EFGH v3 auth notify *tv.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF0F access 10
snmp-server community readONLY RO
snmp-server trap-source Loopback10
snmp-server packetsize 1024
snmp-server queue-length 20
snmp-server location ABC
snmp-server contact XYZ
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps module
snmp-server enable traps tty
snmp-server enable traps bgp
snmp-server enable traps config
snmp-server enable traps hsrp
snmp-server enable traps bridge newroot topologychange
snmp-server enable traps syslog
snmp-server enable traps flash insertion removal
snmp-server enable traps entity
snmp-server enable traps cpu threshold
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server host xx.xx.xx.22 vrf MANAGEMENT version 3 auth admin
snmp-server host xx.xx.xx.21 vrf MANAGEMENT readONLY
564
