Community Member
monitor ports on 2 switches with 1 port analyzer
I've got 2 servers, connected to 2 Cat 6509 individually. I want to monitor both ports with 1 port analyzer (WireShark). if I connect WireShark to one of the switches, and configure 1 SPAN + 1 RSPAN, I can't assign 1 destination port for 2 SPAN/RSPAN sessions. Should I introduce the third switch, and connect WireShark on it?
Re: monitor ports on 2 switches with 1 port analyzer
Are these servers in the same VLAN? If so, did you try to monitor the VLAN they are in?
Mohamad
Community Member
no, in different vlan. Even if they are in same vlan, since they are connected to different switches, Monitoring the Vlan still doesn't work, I think.
247
