Webcast-Catalyst9k
monitor session source vlan /interface
HI ALL, I have encountered some issue and doing trace to check on the issue.say I have dhcp server in vlan 13. Connected to port 1/1/3and host in vlan 46 connected to port 1/1/46.Assuming dhcp relay is configured properly. When I did a span on the both the vlan (monitor session 1 source vlan 13 both and similarly for vlan 46) Accordingly I have specified the destination also. I checked span results and though I connected and able to get dhcp, in the trace I am not able to find the a dhcp packet with source address 0.0.0.0. When I changes the monitor session to be interfaces instead of vlan,I am amble to.see.the dhcp packet with source address 0.0.0.0. Can someone please explain why this is so? Thanks Best Regards, Rakesh
Everyone's tags (1)
116
