Webcast-Catalyst9k
More Than one IP default-gateway
Can you have more that one ip default-gateway on a switch?
Mike
Re: More Than one IP default-gateway
Hi Mike,
No you cannot.
Ankur
No you cannot. But you could try putting the switch's own ip address as default-gateway. If you do that, I think it will ARP for everything, and if your routers are responding proxy ARP for the routes they have, everything should work.
Try it, and let us know if it works OK.
Kevin Dorrell
Luxembourg
130
