10-31-2013 05:13 AM - edited 03-07-2019 04:21 PM
I was trying to move a interface from a VDC to another.
Found the document: http://www.cisco.com/en/US/docs/switches/datacenter/sw/nx-os/virtual_device_context/configuration/guide/vdc_mgmt.html#wp1170127
And tryed to remove from VDC.
When I was trying to do it couldn´t remove it.
(config-vdc)# no allocate ?
fcoe-vlan-range Vlans reserved for FCoE
shared Shared this port using the reserved FCoE vlans
I can allocate interfaces.
(config-vdc)# allocate interface ethernet ?
<1-253> Slot/chassis number (config-vdc)# allocate interface ethernet ?
I was looking for some info at foruns and I saw something about type of modules, but looks like one F2 type have problems. Also checked the user-role and I have network-admin.
This is the output of show module:
Mod Ports Module-Type Model Status
1 32 10 Gbps Ethernet XL Module N7K-M132XP-12L ok
2 48 1000 Mbps Optical Ethernet XL Modul N7K-M148GS-11L ok
3 48 10/100/1000 Mbps Ethernet XL Module N7K-M148GT-11L ok
4 48 10/100/1000 Mbps Ethernet XL Module N7K-M148GT-11L ok
I want to move Ethernet3/32.
This is the source VDC:
vdc nanme id 2
allocate interface Ethernet1/1,Ethernet1/3,Ethernet1/5,Ethernet1/7
allocate interface Ethernet2/1-4
allocate interface Ethernet3/1-2,Ethernet3/32
boot-order 1
limit-resource vlan minimum 16 maximum 4094
limit-resource monitor-session minimum 0 maximum 2
limit-resource monitor-session-erspan-dst minimum 0 maximum 23
limit-resource vrf minimum 2 maximum 1000
limit-resource port-channel minimum 0 maximum 768
limit-resource u4route-mem minimum 8 maximum 8
limit-resource u6route-mem minimum 4 maximum 4
limit-resource m4route-mem minimum 8 maximum 8
limit-resource m6route-mem minimum 5 maximum 5
This is the destination VDC:
vdc name id 4
allocate interface Ethernet1/17-32
allocate interface Ethernet2/9-12
allocate interface Ethernet3/3,Ethernet3/9-30
boot-order 1
I tryed to use allocate with "shared" but it didn´t work. All intertafaces looks like "ok" on membership status.
Solved! Go to Solution.
10-31-2013 05:44 AM
In order to move/add ports from one VDC to another, you would need to be in admin VDC.
10-31-2013 05:44 AM
10-31-2013 06:19 AM
Now I understood what I´ve done wrong...
We have 4 VDCs. On my mind first (ID 1) should be admin and it was default vdc.
Now I will look how to change it to Admin-VDC.
Thanks.
