MPLS - GRE tunnel routing problem
The problem we have is that the GRE tunnel becomes the primary route when both ciruits are up. EIGRP sees it as a better route over our MPLS circuit.
At the moment we have passived the tunnel interface, but this then doesn't give us the automatic failover we require.
Is there a way that I can make EIGRP see the MPLS circuit as the primary one?
Your help will be much appreciated.
Re: MPLS - GRE tunnel routing problem
Check your bandwdith and delay settings in your GRE tunnels.
Make your MPLS tunnel the best route from both sides, something like:=
MPLS tunnel
Bandwdith 10240 = 10mbs or whatever the circuit speed is.
delay 500000
Backup tunnel
Bandwidth 10240 = = 10mbs or whatever the circuit speed is.
delay 1000000
With the above - EIGRP will choose the MPLS as it has a lower delay = better route.
These settings must be used at both ends - otherwise you will have asymetric routing, the traffic will go over the MPLS and return on the backup.
HTH.
We have tried this, without any effect.
I believe it is do with getting the route internally over the tunnel, but externally accross the MPLS link.
sh ip route 10.220.1.1
Routing entry for 10.220.1.0/24
Known via "bgp 65011", distance 20, metric 0
Tag 2006, type external
Redistributing via eigrp 100
Advertised by eigrp 100 metric 64 20000 255 1 1500 route-map IST_MPLS_Networks_in
Last update from 146.200.22.53 04:23:52 ago
Routing Descriptor Blocks:
* 146.200.22.53, from 146.200.22.53, 04:23:52 ago
Route metric is 0, traffic share count is 1
AS Hops 2
Route tag 2006
148
