MQC LLC QOS not working with WS-X6704-10GE
I have a site trying to do the following:
service-policy output voip
and receives the following error:
priority command is not supported in output direction for this interface
I found that the WS-X6704-10GE doesn't support "priority" queueing. So, what line cards will support priority queueing on a CAT 6509? Or is there another way to configure?
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: MQC LLC QOS not working with WS-X6704-10GE
Ah okay. You can't use the MQC LLC priority command set because you don't use MQC commands for egress queueing on catalyst switches.
The 6704-10GE does have a priority queue which you can use for priority traffic for voice etc. but you don't configure it with the priority command. You need to set up which CoS/Dscp values go to which queue and how much bandwidth each queue gets.
Attached is a link to QOS config on 6500 with an example including a priority queue -
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/qos.html#wp1750910
Jon
Richard
"I found that the WS-X6704-10GE doesn't support "priority" queueing."
Where did you find confirmation of this because these 2 docs suggest that the 6704-10GE has a TX queue system of 1p7q8t -
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/product_data_sheet09186a00801dce34_ps4835_Products_Data_Sheet.html
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/prod_white_paper09186a0080131086.html
Jon
Jon,
I googled it and found the following information:
> Configuration failed!
Yup! It did! ..and it will on ws-x65xx, 67xx, and 68xx cards. You need
OSM, SIP/SPA, or 20G line cards for MQC LLQ (low latency queuing, aka.
'priority' in the policy-map) to work.
So, I went from that information. If I am wrong about this, then why am I getting the "not supported" error?
Jon
I see..Okay..Thanks, that makes total sense.
440
