MSFC card not loading on SUP2 Module (6509)
I have a load issue I cannot seem to rectify.
When the SUP2 module loaded the CatOS 6.3.3 I went into session 15 to access the MSFC card I found the prompt was router(boot)
I guess this mean that no valid IOS was found on the bootflash:
I did a dir bootflash: and found 2 versions of IOS to load.
I went into "conf t" and did a boot system bootflash:<IOS filename> and reloaded the 6500.
Session 15 no longer comes online. I guess the IOS was corrupt or invalid.
I cannot seem to get into session 15 anymore.
I do a show module 15 and it tells me the module is offline
Any ideas.
Silver
Re: MSFC card not loading on SUP2 Module (6509)
Try using the SWITCH CONSOLE 15 command to get into the MSFC. From their you can set up the correct IOS to boot off of..Good Luck....
Purple
Check the config register on the msfc and make sure it is 0x2102 and the image you are trying to load is a valid Sup2 MSFC image.
340
