Community Member
MSFC1 v MSFC2
I need to research the differences between MSFC1 and MSFC2. What slot/ chassis do they fit into?
Feeling a bit overwhelmed as it all new to me!
Any pointers gratefully received, thanks.
Re: MSFC1 v MSFC2
The MSFC and MSFC2 are daughter cards that plug directly into a Supervisor Engine. The MSFC and MSFC2 contain:
A processor
Processor memory
A system controller
Bootflash
These devices provide a means to perform Multilayer Switching (MLS) and interVLAN routing.
The MSFC has a MIPS R5000 CPU that runs at 200 MHz internally. The MSFC supports memory options that range from 64 MB to 128 MB.
The MSFC2 has a MIPS R7000 CPU that runs at 300 MHz internally. The MSFC2 supports memory options from 128 MB to 512 MB. The device also has Error-Correcting Code (ECC) memory protection/correction for single-bit errors and the detection of multibit errors.
You can visually distinguish the type of MSFC that you have. Look at the number of DRAM slots. The MSFC has two DRAM slots that are stacked on top of one another. The MSFC2 has only one DRAM slot.
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008013495f.shtml#plat_desc
HTH,
Mohammed Mahmoud.
Community Member
Re: MSFC1 v MSFC2
Hi Mohammed,
Thank you, you're a legend! Really appreciated, thanks again.
Simon
Re: MSFC1 v MSFC2
Hi Simon,
You are very welcomed and thank you for your kind words, please do come back if you have more questions :)
HTH,
Mohammed Mahmoud.
158
