MST/PVST Boundary
I have an MST region with istance 1 mapped to vlans 1-500. The MST boundary switch has an interface which connects to another switch running PVST.
My question is, when a BPDU is sent from within the MST instance 1 for VLAN 45 (for example), will the PVST region recieve BPDUs for just VLAN 45 or for all VLANs mapped to the MST instance (1-500)?
I am confused by this line in the 6500 series command reference guide;
"The ports that belong to the MST switch at the boundary simulate PVST+ and send PVST+ BPDUs for all the VLANs."
Any help would be much appreciated!
Tom.
1 ACCEPTED SOLUTION
Re: MST/PVST Boundary
Hi Tom,
The Cisco MST switch detects neighbor running PVST as soon as it received a PVST BPDU. Then, it replicates the BPDU for instance 0 (the CIST) on each an every vlan configured on the port. This is a boundary port, meaning that only the CIST information is relevant (your MST instance 1 information will not be used). So on the PVST switch, each vlan receives a BPDU coming from the MST bridge, and each vlan instance receives information from MST instance 0.
HTH,
Francois
An mst region appears to the rest of the network as ONE bridge, so the switch that connects mst to pvst will send a bpdu representing the entire region.
It is better for you to Switch only to PVST+
because if there is a loop on MST Region it will block all VLAN's for PVST+.
Hi Tom,
HTH,
Francois
1123
