Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
MST / Rapid-PVST
having a data center with 2 6506 Core switch and 25 3560 distribution/access switch
Using 25 differents vlan and only layer 2 switching, layer 3 is on 7600 routers due to network design.
At this time, using Rapid-PVST on this site and works fine
We plan to install an other data center with the same configuration, and both sites will be connected through DWDM
We want to see this 2 data centers as unique layer 2 lan (routing always on 7600 routers)
I plan to use now MST. What are the best benefits of MST versus R-PVST ? Reduce BPDU msg, is network convergence ok ... ???
We use 12.2(25) SED1 on 3560 and 12.2(18) SXF5 on 6506
Gilles
1 REPLY
Re: MST / Rapid-PVST
They are essentially the same, 802.1w and 802.1s... both are IEEE standards now. MST has less BPDU messages, convergence should be the same as each other.
MST, I believe you no longer have the option of VTP... so you'll have to configure all the switch VLANs individually.
You may want to read the document below for further understanding. Looks complicating if you are going to mix environments.
URL: http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_guide_chapter09186a008007e71a.html#wp1050594
341
