MST(STP) help needed....weighting links, etc..
I need some help doing some manual tweaking with MST(STP). Here is the scenario.
We have two load balancers with two uplinks (gigabit) going to two 6509s (one link each for a mesh configuration). There is a primary and a secondary load balancer.The second only takes over if the first box dies.
The load balancers can run MST but it has been recommended by the vendor not to run MST/STP so the load balancers are only doing passthru of BPDUs and NOT participating in the MST/STP algorithm. I need to know what the commands are to tweak the weighted values to make the load balancers fail in this particular order:
Primary LB - uplink #1 . then
Primary LB - upnlink #2 which goes to 6509#2, then
Secondary LB - uplink #1 which goes to 6509#1, then
Secondary LB - uplink #2 which goes to 6509#2.
Can someone give some advice please and perhaps the commands to make the Cisco weight out the links correctly so that MST/STP fails from link to link in the above listed order? Any information is highly appreciated.
Thank you,
  • LAN Switching and Routing
1 REPLY
Re: MST(STP) help needed....weighting links, etc..
Hi Jake,
I'm not sure yet about the design. Here are some few additional questions:
-Is there a L2 link between the cat6ks, beside the connection through the load balancers?
-Is the secondary load balancer (let's call it LB2) forwarding traffic between its uplinks when it is in standby mode.
-Are you attempting to distribute traffic on several vlans, in order to use several uplinks at the same time, or are you ok with just one uplink being active at a given time for all the L2 traffic.
-Also, something stupid, how do you switch over from LB1 to LB2 if LB1 loses both its uplinks 1 and 2 to the cat6k?
A priori, I would say that making cat6k1 the root should be enough.
Francois
129
