04-05-2007 04:09 AM - edited 03-05-2019 03:19 PM
Is the MTU limitation on Fastethernet ports on Cisco routers in hardware or in software.
I am trying to increase MTU size on FE port to avoid frengmentation of GRE packets exiting the interface but I get % Interface FastEthernet0/0 does not support user settable mtu.
Is there any workaround? Or is there any cisco router that supports changing MTU on Fastehernet ports (not Gigabitethernet).
Tnx
04-05-2007 04:46 AM
Hi Friend,
Can you try changing the mtu value with "ip mtu" command?
Ankur
04-05-2007 05:07 AM
ip mtu does not allow me to set value greather than 1500
04-05-2007 04:48 AM
FE ports should be following 802.3u standard. I don't think it will take MTU longer than what standard calls for. Payload can be max 1500 bytes.
Thanks.
