MTU Limitation on Gig Interface
I read that the PA-GE module on the 7200 supports an mtu of >1500.  I'm trying to set mine to 1546, but cannot.  What command do I enter to enable support for this size?
EDR01#config t
Enter configuration commands, one per line.  End with CNTL/Z.
EDR01(config)#int gig 5/0
EDR01(config-if)#ip mtu 1546
% Invalid input detected at '^' marker.
EDR01 (config-if)#ip mtu ?
  <68-1500>  MTU (bytes)
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: MTU Limitation on Gig Interface
Hello David,
it is also a question of IOS image
also you need first to increase mtu with mtu command then you may be able to increase ip mtu
Hope to help
Giuseppe
Hello David,
Hope to help
Giuseppe
Version 12.4 (12.2r) T
Cisco 7200
Card is PA-GE (trying to change Gig 5/0 on this card)
Thanks....
int gig 5/0
mtu xxxxx
501
