07-28-2010 01:25 AM - edited 03-06-2019 12:13 PM
Hi all,
In my company we want to connect a server to two Catalyst 6500 forming a Etherchannel in order to have greater redundancy without losing bandwitch.
Looking for information, I have read that it is possible with Multi-chasis LACP protocol (mLACP).
We have two Catalyst 6509 with two supervisors SUP-7203B each in SSO mode.
This is my doubt:
Could we configure it with those supervisors or we need upgrade to VSS supervisors?
Thanks!!!
Iker.
Solved! Go to Solution.
07-28-2010 05:51 AM
Hi Iker,
To have switch redundancy and also NIC redundancy, you would need to set up your 6500 as VSS, but for VSS you need Sup-720-VS with PFC 3C or 3CXL. Sup-720-3B will not work.
Reza
07-28-2010 05:51 AM
Hi Iker,
Reza
07-29-2010 03:57 AM
Thanks a lot
