01-31-2008 07:29 AM - edited 03-05-2019 08:51 PM
I'm putting in a new VMware EMS server for testing, our first. I'm not going to run trunks to this server but it is going to be attached to two different Catalyst switches that are trunked together. Since the EMS server has it's own virtual ethernet switches do I have to be concerned with spanning tree? I usually have portfast on to switch ports that connect to servers should I not do that in this case? Any other considerations I should address that someone here has come accross?
Solved! Go to Solution.
01-31-2008 07:41 AM
You do not have to worry about STP. View the PDF for more information.
http://www.vmware.com/files/pdf/virtual_networking_concepts.pdf
01-31-2008 07:41 AM
