Multicast Anycast RP and MSDP question
I have two rendezvous points on different routers with MSDP peering between them setting up an Anycast RP environment. Here are the router's config regarding multicast:
Router1:
interface Loopback0
ip address 16x.x2.239.5 255.255.255.255
interface Loopback1
ip address 16x.7x.239.42 255.255.255.255
ip pim sparse-mode
ip pim rp-address 16x.7x.239.42
ip msdp peer 16x.7x.239.18 connect-source Loopback0
ip msdp originator-id Loopback0
Router2:
interface Loopback0
ip address 16x.7x.239.18 255.255.255.255
interface Loopback1
ip pim sparse-mode
ip msdp peer 16x.7x.239.5 connect-source Loopback0
I have 'ip pim sparse-mode' on every interface - but do I need to have 'ip pim sparse-mode' on the L1 interfaces?
1 ACCEPTED SOLUTION
Re: Multicast Anycast RP and MSDP question
Configuring "ip sparse-mode" on the loopback interface is only required if you use auto-rp. It wouldn't be required in your case.
hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222 Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
hope this helps,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Cuauhtémoc, Juárez
México
If I may I'd like to ask another question concerning the placement of the RPs. I want two of them in my environment for redundancy and will config the L1 interface of both the same as in the MSDP example.
Since all of our enterprise traffic comes into our main campus for internet access, server host system access, video streaming services etc, is it best to have both RPs here at the main campus?
I know I can have them anywhere, but was also told to have them closest to the actual multicast servers in order to keep the shared-tree state to a minimum (I don't know if I am expaining it correctly)
Anyway I'd like to have the two RPs be our two distribution WAN routers which are one hop away from each other.
Does that sound OK, or would you recommend I disperse the two RPs to different geographic sites?
452
