02-08-2008 12:10 PM - edited 03-05-2019 09:02 PM
Dear Net Pro!
how to configure:
assign R1 as a RP For Groups 228.28.28.28 & 228.26.26.26 R2 must be Backup RP fpr R1
MANY 10XS
02-08-2008 12:49 PM
Does it tell you to use Auto-RP, BSR or Static RP ?
It may be one of those CCIE type of questions where they want you to use Auto-RP on this scenario.
Auto-RP, by default, will choose the highest IP address between 2 devices (so in this case, it will choose R2). The workaround is selecting another interface with a lower IP in R2 so it can be considered a backup RP.
Please reply if that's the case.
__
Edison.
02-09-2008 08:26 AM
Hi edison
yes Via AUto RP..
10XS
02-09-2008 01:20 PM
Then do as I recommended, when mapping the groups make sure the send-rp-announce is referring to an interface with a lower IP address on R2 than R1.
Usually, you pick the loopback IP but that's not mandatory. You can pick any interface from the router.
A Sample Auto-RP configuration can be found here:
HTH,
__
Edison.
02-10-2008 08:20 AM
Hi Edy
10xs for Ur reply..
