Multicast Issue
kian_hong2000
Say i have enable ip multicast-routing on Switch A, B and C. Switch B is a core switch. Next i put in the commands on Switch A, B and C
Connection link
PC C > SwC > SwB > SwA > PC A
SwA (Distribution Switch)
int gi1/1 to SwB
channel-group 2 mode on
Vlan A
ip pim sparse-dense-mode
no ip route-cache cef
ip cgmp
no ip mroute-cache
Port Channel 2 to SwB
ip cgmp
SwB (Core)
int gi1/1 To SwA
switchport
switchport access vlan B1
switchport mode access
no ip address
vlan B1
ip cgmp
int gi1/2 to SwC
switchport
switchport access vlan B2
no ip address
vlan B2
ip cgmp
SwC (Server farm)
int gi1/1 to SwB
switchport access vlan C
Vlan C
ip cgmp
no ip mroute-cache
Then I insert PC A to Switch A port and from PC C to Switch C port.
I do a ping from PC A to PC C and it work. However, if i use iperf, i am not able to capture the multicast packets from PC A to PC C
Does fast-switching cache affect multicast to be enable in the network?
mchin345
Level 6
Level 6
Complete these steps to determine if the source is actually sourcing the packets and inserting the correct packet fields:
1. Check the interface counters on the host. First, check the interface counters (if you are on a UNIX system, use the netstat command) on the source host to see if it is sending packets. If it is not, check for misconfiguration or bugs in the host stack and application.
2. Use the show ip igmp groups interface-name command to check the upstream router to see if it received a join membership report at the interface directly connected to source.
Here is the link for Basic Multicast Troubleshooting Tools.
http://www.cisco.com/en/US/tech/tk828/technologies_tech_note09186a0080093f21.shtml#sourcepacket
