Multicast issues on LAN and WAN
Hi all. I was hoping to get some help with this. We have Video Conferencing equipment with multicast streaming capability. We want to use it to multicast a company President's speech in a few months.
For our current issue, I'm only going to focus on our basic network routing structure between the source and our test receivers. The first router hop is a 6509 with MSFC for local VLAN routing, then a 7204VXR router for WAN connectivity that connects to a 7204VXR in our DC office, a 3662 in our nearby phone center. We're trying to confirm streaming to the DC and Phone Center locations first.
I start the streaming and have it using group 224.2.23.209. The initial connection is using a URL to http://10.0.31.3/stream.sdp. If I use QuickTime to open this stream, it works. If I do the same on any machine on a 10.x.x.x network VLAN off of the MSFC. The one exception is the VLAN that uses an IP subnet of 38.233.146.x (relic from pre-NAT days). This subnet is also the one that the 7204 WAN router exists on.
So I can multicast stream across any VLAN on the MSFC except this one.
I think If I can fix the stream problem to that VLAN, I can get the multicast across the WAN working.
On the routers we're using the ip multicast and ip pim sparse-mode configuration commands. And that's about it. I read that we don't need an RP in sparse-mode because the routers should figure out which one needs to be an RP.
It seems like the 7204 and the MSFC will peer with each other. Yet it seems like the 7204 never gets the multicast group joined on it, even when a machine across the WAN requests the stream.
I didn't think multicast was this difficult to configure. I had it working easily between most of the local VLANs using the simple ip multicast and ip pim sparse-mode commands, just not sure why that one VLAN and the WAN are being such a problem.
Any help is appreciated.
Thanks.
Hall of Fame Super Silver
Re: Multicast issues on LAN and WAN
Hello James,
with PIM Sparse mode you need to define the RP.
There are different ways to do this and to propagate this info
the simplest way is manual configuration
on all routers except the RP
put
ip pim rp
where rp-address is a loopback address advertised in the unicast routing protocols
Depending on IOS release the command can be skipped on the RP itself or needs to be defined.
check with sh ip pim rp mapping
Without it can work between vlans of the core C6509 because there is no need to build a spanning tree
When the spanning tree is on more routers the RP helps in the initial building of a shared tree.
Hope to help
Giuseppe
Thanks for the info Giuseppe.
I'm a little rusty and don't use loopbacks much in actual practice. Can you expand on what you mean about "where rp-address is a loopback address advertised in the unicast routing protocols"?
Also, is the RP still necessary is Auto-RP is enabled?
Thanks.
Bronze
Create a loopback interface-
interface loopback 0
ip address X.X.X.X 255.255.255.255
A /32 bit mask is fine for a loopback. Keep in mind that this loopback addressing can't overlap with anything else in your network. (So if you have a server vlan that's defined as a /24, you can't pick your loopback to be addressed out of this range.)
Once that Loopback is defined, you simply have to drop it into your dynamic routing protocol with the appropriate network statement. (OSPF, EIGRP, RIP, what have you.) Or update all your static routes if that's the way you roll...
Loopbacks area good practice to get into because they can never go down!
Imagine you've got a WAN router with two WAN interfaces, and a LAN interface. When you connect to the box remotely, you're in the habit of telnetting to the LAN ethernet address.
Now let's say the Switch at that site goes down- the LAN link is down, and isn't advertised. Now you can't telnet to that IP address.
Same goes for various permutations of if you're used to connecting to various WAN interfaces.
If you connect to the Looopback, which is dynamically routed... it doesn't matter which permutation of interfaces is up/down, as long as there's some form of connectivity of the box, you know exactly which address you can telnet to. Same goes for sourcing of Syslog, NTP, TACACS, and any other number of services that are hopefully interface agnostic.
Hello James ,
yes, but you need different commands to declare a candidate RP and to define a mapping agent (they can be the same router)
I would suggest you to stay on manual config for the first setup
later you can add complexity to your solution
for the first question you have already received useful information
Best Regards
Hope to help
Giuseppe
Thanks a lot for the help. The Loopbacks and defining the RP's on the routers did the trick.
Thank you!!!!
Hello James,
nice to hear that you solved your issue.
Thank for your good remarks.
It is a good practice to report if the suggested solutions work because in this way the case story is completed and is useful for everyone that reads and wants to learn about the subject.
Best Regards
Giuseppe
276
