Multicast over a GRE tunnel
I setup a GRE tunnel between two cisco 3725 routers following
http://www.cisco.com/en/US/tech/tk828/technologies_configuration_example09186a00801a5aa2.shtml
They are both running IOS c3725-ipbase-mz.123-9e.bin. When I do a show ip int brief they both show up/down! So I seem to have a problem with the protocol! I cannot ping the tunnel address at the far end. I have checked both of the tunnel interfaces and they seem fine.
My IP cloud consists of some Nortel 7440 multiservice switches.
I have looked all over the cisco site trying to find some troubleshooting
information but, I don't see anything that applies.
Here is a copy of my configs:
MCast 1:
ip multicast-routing
frame-relay switching
no ftp-server write-enable
interface Loopback0
ip address 2.2.2.2 255.255.255.255
interface Tunnel0
ip address 192.168.0.1 255.255.255.0
ip pim sparse-dense-mode
tunnel source Loopback0
tunnel destination 4.4.4.4
interface FastEthernet0/0
ip address 10.120.255.1 255.255.255.0
speed 100
full-duplex
interface Serial0/1
ip address 10.120.254.1 255.255.255.0
encapsulation frame-relay IETF
ip ospf network point-to-point
no fair-queue
frame-relay interface-dlci 16
frame-relay lmi-type q933a
frame-relay intf-type dce
router ospf 1
log-adjacency-changes
network 2.2.2.2 0.0.0.0 area 0
network 10.120.0.0 0.0.255.255 area 0
network 192.168.0.0 0.0.0.255 area 0
ip classless
no ip http server
ip pim bidir-enable
MCast 4:
no ip domain lookup
interface Loopback0
ip address 4.4.4.4 255.255.255.255
interface Tunnel0
ip address 192.168.0.2 255.255.255.0
tunnel destination 2.2.2.2
ip address 10.120.244.1 255.255.255.0
duplex auto
speed auto
interface Serial0/1
ip address 10.120.245.1 255.255.255.0
router ospf 1
network 4.4.4.4 0.0.0.0 area 0
ip classless
no ip http server
ip pim bidir-enable
ip mroute 10.120.255.0 255.255.255.0 Tunnel0
Any help would be much appreciated. Thanks.
Mark
Re: Multicast over a GRE tunnel
Did you confirm endpoint reachability? Use an extended ping with source 2.2.2.2 and dest 4.4.4.4 or vice versa.
If this does not work, troubleshoot your IP network.
If this works then shut/no shut the tunnel interfaces.
Please report the outcome for further help.
Regards, Martin
Hall of Fame Super Silver
Andy
I believe that Martin has given you very good advice in suggesting extended ping to check reachability from 2.2.2.2 to 4.4.4.4. I suspect that you will find that the extended ping fails and reveals that the fundamental problem at this point is lack of reachability.
From my experience there are 2 things that will produce the symptom of GRE tunnel interfaces as up/down. One is that GRE keepalives are configured (and they are not in your config) or that the router does not have a valid route to the tunnel destination. You can confirm this with show ip route on either or both of the routers. I suspect that you will find that 2.2.2.2 is not in the routing table of the other router.
I also observe that I believe you will have an additional problem with recursive routing once you get the basic IP connectivity issue resolved. It is a frequent problem with GRE tunnels if you advertise the tunnel end point in the routing protocol running over the tunnel (and the network statements for 2.2.2.2 and 4.4.4.4 along with 192.168.0.0 under OSPF will do just that). Essentially what happens is that when the tunnel comes up and the routing protocol running over the tunnel advertises the tunnel end point (2.2.2.2 or 4.4.4.4) as reachable through the tunnel, then the router when it has an encapsulated GRE packet to transmit will attempt to transmit it over the tunnel rather than transmitting it out the physical interface. The easy solution to this issue is to configure a static route for the /32 host address pointing to the outbound physical interface.
Rick
852
