Webcast-Catalyst9k
Multicast "router alert" problem on cisco L-3 switches
Hi.
I have a problem on IBM UNIX servers (NO problem on Microsoft OS).
The UNIX does not send in the IGMP report the "router alert" option (the UNIX can NOT be upgrade)after the first IGMP join to a multicast group.
after 4 minutes the UNIX loses the multicast group.
I am looking for a way to keep the membership of the UNIX to the specific Multicast group even though no "router alert" option is being send to the L-3 switch.
Any idea???
Thanks.
Silver
Re: Multicast "router alert" problem on cisco L-3 switches
For your requirements you should upgrade host stack to IGMP version 2 or IGMP version 3 .
Alternatively you can use "ip igmp snooping querier" on a router interface connected to the VLAN if you do not want to goto IGMP v2 or 3.
Nick
Thank you Nick.
I will try it also.
Best regards,
Danny.
Thank you.
I will try it.
Danny.
i have a problem whith the IGMPv2 Query from my C3750.
This Query comes without IP option "router alert".
How do i activate this?
Thank you.
241
