Bronze
Multicast: switch doesn't accept proper RP-discovery message
Hi all,
We have a very strange problem on a C6500 running 12.2(33)SXH4
We are using Auto-RP for Rendez-vous point distribution and this is working fine, only on one switch the
RP-discovery packet is ignored. See message below from "debug ip pim auto-rp"
Auto-RP(0): Received RP-discovery, from 10.96.24.4, ignored
Auto-RP(0): Received RP-discovery, from 10.96.0.1, ignored
I have no idea why this packets is 'ignored'. The system itself is a mapping agent (for other ranges), but that should not
prevent it from accepting other RP-discovery packets.
I have checked RPF failures. The routing table is correct so their should not be a problem here.
Below is the MC configuration (without ip pim on interfaces):
no ip pim dm-fallback
ip pim autorp listener
ip pim send-rp-announce Loopback100 scope 15 group-list SITE-RP
ip pim send-rp-discovery Loopback0 scope 15
ip pim rp-announce-filter rp-list RPS
ip pim accept-register list ALLOWED-MC-SOURCES
What i have noticed is the following:
from the moment that i remove "ip pim send-rp-discovery Loopback0 scope 15" (mapping agent), the switch accepts
the received update. When i put it in -> doesn't accept the update again. Very strange.
regards,
Geert
1 REPLY
Community Member
Hi Geert,
Hi Geert,
Not sure if you are still follow this question. I searched this: http://ieoc.com/forums/t/17606.aspx
Mapping Agent will ignore another MA advertisement; however both MAs will send out their advertisements, and all devices will hear both announcements.
Not sure if this statement is true, but I observed that the Mapping Agent is ignored RP discovery messages from other MAs as well.
Thanks.
291
