Community Member
Multicast
Recently replaced our core campus switch with a 6513. Our edge switches consists of 3750s and some Avava Cajun 330.
Our IT staff uses Ghost to image PCs. They said since the core was replaced multicast for Ghost no longer works.
Our old core Avaya 882 switch had multicast enabled. Our Cajun 330 edge switches support the following for multicast. The Avaya P330 supports multicast filtering. The P330 learns which switch ports need to receive which multicast packets and configures the necessary information into the switch's hardware tables. This learning is based on IGMP (version 1 or 2)snooping.
I need to know how to enable multicast on the 6513 for Ghost and also on the 3750s. The Cajun 330s have what they call intelligent multicast as described above and need them to work with multicast as well.
The IT staff is using Ghost across a numbers of VLANs. To prevent network issues is there a best practice for use Ghost on our campus network so as to not saturate the nework. Is there a means to throttle Ghost?
Craig
1 REPLY
Hall of Fame Super Silver
Re: Multicast
Hello Craig,
in your core router you need
ip multicast-routing
ip pim dense-mode on all SVI VLans
on C3750 you just need to check the igmp snooping is enabled with sh ip igmp snooping
see the following link
http://www.cisco.com/en/US/docs/ios/ipmulti/configuration/guide/imc_basic_cfg_ps6441_TSD_Products_Configuration_Guide_Chapter.html
About how to control Ghost BW usage you should use modular QoS to shape this type of traffic
http://www.cisco.com/en/US/docs/ios/qos/configuration/guide/polcing_shping_oview_ps6441_TSD_Products_Configuration_Guide_Chapter.html
hope to help
Giuseppe
335
