03-11-2008 01:23 AM - edited 03-05-2019 09:40 PM
Multilayer Campus Design
Layer 2 Access with Layer 3 Distribution
im trying to set up a network with a l3 in the distribution and a l2 in the access
L3 L3 (3845)
|-----L3-------L3---| (3750)
L2
But im getting in to troubles when i deploy it
The core is 3845 routers the distribution is 3750 switches talking in between them EIGRP the cross link is a L3 ether channel,
The L2 switch is also a 3750 switch with a MGT VLAN
The vlans are configured on the two distribution switches as (SVI's) and are know in the whole network, no issues there
The problems staring when i test the failover (HSRP) , i disconnect a trunk on the l2 switch and all the network is falling,
EIGRP neighbors go down
HSRP takes a long time to fail over
All Vlan disconnect
but when i make the crosslink a L2 Trunk... then all is good
Who can advise?
Thank you
03-11-2008 03:31 PM
Thanks to you all guys,
I'm glad I'm not alone with this issue and all are really trying to help, thank you
Ok
Let's summarize (see drawing),
I've a two 3845 routers (WAN routers) and two 3750 as the core/distribution switches
All there 4 network components I would like to have speaking EIGERP
I have also a L3 cross link (ether channel) in between the 3750's,
So far all is good and the network is working, But When I disconnect one of the trunks to the access switches (L2) the problems starts
The SVI's (my Vlans) that I configured on the 3750's go down, I see that HSRP takes very long to switch, And all my EIGRP neighbors are going down as well
Is this a Spanning tree issue, Convergence (PVST)?
Now when I configure the cross link from a L3 to a L2 trunk all seems to work fine
So the questions I have now are as follow
Is this the right logic? Is this the way it should be (EIGRP with a L2 trunk ?)
And Spanning tree ive chosen for Rapid spanning tree protocol (802.1W, was PVST before) any tips?
Thank you all
Ill do some new test with a L3 cross link and Rapidspanning tree
Is this the right logic? Is this the way it should be (EIGRP with a L2 trunk)?
And Spanning tree I've chosen for Rapid spanning tree protocol (802.1W, was PVST before) any tips?
Thank you all
Ps.
I know that Cisco is promoting to implement L3 all the way to the Access layer, but it is not possible for me with this design because I have more then one vlan per access switch and this VLAN is being used on other access switches too,
03-12-2008 12:49 AM
I'm assuming that on each 3750 distro switch you have the same vlans running HSRP eg
3750_1
int vlan 10
ip address 192.168.5.2 255.255.255.0
standby 10 ip 192.168.5.1
etc...
3750_2
int vlan 10
ip address 192.168.5.3 255.255.255.0
etc...
With a L3 etherchannel between your 2 distro switches the HSRP packets have to traverse the access-layer switches ie. they cannot go directly across the L3 etherchannel.
So, and again it is difficult to be precise without configs etc, when you disconnect a trunk from the access-layer to the distro layer an STP calculation will in all probability start. While STP reconverges no traffic is passed over the access-layer so that means no HSRP traffic can go between the 2 distro switches.
So bearing in mind you cannot do L3 at the access-layer as you say i would recommend
1) Migrate to RSTP - this should significantly speed up your convergence times.
2) Optionally you can change the L3 etherchannel between your distro switches to a layer 2 trunk and then ensure that any blocked ports are to the access-layer switches and not between the 2 distro switches.
Oh yes and
3) Stop disconnecting trunks :-)
Let us know how you get on with your tests
Jon
03-12-2008 12:57 AM
The convergence should be faster even with PVST if you make sure the core switches are the root for the vlans and you have uplinkfast enabled on the access switches.
Narayan
Never thought that there would be so much discussion on this topic :-)
03-12-2008 01:07 AM
Hi Narayan,,
It's a tough topic but confusing im glad a lot of people are looking at it,
Thank you Narayan for getting me in the right direction
Ill do some test today and let you know
03-12-2008 01:02 AM
Jon
Thank you for your Feed back
I think the RSTP will change the speed /convergence big time but I also think that it is not possible without the L2 Trunk,
Ill do the to test
Test 1 L3 ether channel with RSTP
Test 2 L2 trunk with RSTP
Ill let you know later what I found out
Thanks for now
03-12-2008 01:10 AM
No problem, although having just reread the post i've made a bit of a basic error. So before someone a lot smarter than me ie. all the others on this post, jumps in
It isn't an STP issue as you do not have any loops in your network. Because you are running a L3 etherchannel between your distro switches and L3 uplinks to your 3845 routers all your trunks from the access-layer should be forwarding.
Apologies for misleading you.
Jon
03-12-2008 04:29 AM
re: STP loops
From one of OP's later posts:
"Ps.
I know that Cisco is promoting to implement L3 all the way to the Access layer, but it is not possible for me with this design because I have more then one vlan per access switch and this VLAN is being used on other access switches too,"?
[edit]
re: uplink fast
Automatic feature of RSTP?
03-12-2008 01:56 PM
Hi to all,
The good news is that's it working
The bad news is that im back to L2 between the Distribution switches.
This is the short version of the tests
I have tested with two access switches and two distribution/core switches
I had 2 laptops on two different Vlans, pinging each other from two different switches,
During the many trunks disconnects and I've tried many variations (with and with out cross connect, one with the two primary trunks disconnected, and so on â¦
It was working but not fast and some pings were failing (timeouts)
I connected a third access switch during these test and I've notice that all was working good suddenly, (the third switch became a transit switch all traffic was going through it),
Is tough to explain / show with out the config. Files
But the moment I reconfigured to L2 trunk (etherchannel) all test were good with out any ping timeouts
So now you know what I chose for,
Thank you all for the great tips and different views
