04-14-2012 02:00 AM - edited 03-07-2019 06:07 AM
Hi.I have setup two DHCP pools on a router that performs with Inter-VLAN routing between a L2 switch.Do I have to configure anything so that the router can assign the correct DHCP pool to the correct VLAN host or does It do that automatically by looking at the Network portion of the DHCP configuration ?
Thank You
Solved! Go to Solution.
04-14-2012 04:02 AM
04-14-2012 04:02 AM
04-14-2012 04:47 AM
Thanks! So as long as you have the Inter-VLAN routing It knows which IP pool to point to from what I've understood
