Webcast-Catalyst9k
Multiple HSRP groups on 4503 (Sup2 Plus TS)
I'd like to setup an HSRP architecture between 2 6500 (MSFC2) and 1 4503 (Sup2 plus TS).
The Idea is to use 2 HSRP Groups for each VLAN. (I will have 2 gateways for each VLAN)
But I would like to know how many groups I can use on the 4503?
I found this URL for the 6500, but nothing for Catalyst 4500.
http://www.cisco.com/en/US/products/hw/switches/ps700/products_qanda_item09186a008011c6bb.shtml
1 ACCEPTED SOLUTION
Silver
Re: Multiple HSRP groups on 4503 (Sup2 Plus TS)
All of the supervisors support 256 HSRP groups the only exception is the Supervisor 2 which supports 16 groups only.
In the sup2 16 HSRP groups does not mean that you can have only 16 HSRP processes or 16 VLAN interfaces with HSRP enabled. So a possible approach would be for example:
Vlan 1 - standby 1
vlan 2 - standby 2
vlan16 - standby 16
vlan17 - standby 1
1 REPLY
Silver
Vlan 1 - standby 1
vlan 2 - standby 2
vlan16 - standby 16
vlan17 - standby 1
314
