Multiple ISAKMP SA's are showing up
Ricky Sandhu
Level 3
Level 3
Hi everyone, I have router (spoke) that connects to two DMVPN hubs over 2 IPSEC tunnels. When I perform a show crypto isakmp sa command, I see multiple SAs to IP addresses that I don't recognize. I should only have two SA's (one to each DMVPN hub). Can anyone shed some light as to why these security associations with unknown IPs are showing up?
Latchum Naidu
You will see that when you have a crypto map pointing to default network like below. This you need because when you are in DMVPN cloud then the spoke to spoke virtual tunnel must be established so that they can communicate directly without coming to HUB which is the main advantage in DMVPN technology.
crypto isakmp key xxxxxxxxxx address 0.0.0.0 0.0.0.0 no-xauth
Please rate the helpfull posts.
Naidu.
Latchum Naidu
Naidu.
Thank you Naidu. That explains it.
You are most welcome.
Please close "click on the correct answer" the case if this answered your query.
Naidu.
