I currently have a setup consisting of two 3650 switches, a microwave link between the two, and a mesh wireless network with root APs on each switch. This causes a loop. I would like to use both links as the Microwave is a much faster connection between the two, however we have devices connected to the mesh that need to connect to both switches. Is there some sort of least cost routing or something that I can pull this off? If I understand correctly, STP will bring one link down until it is needed. Any help would be appreciated!
