Multiple public IP's on ASA5510 forward to correct VLAN
kurtcarlson
I am planning 3 VLAN's on my Cisco 2960 switch to serve our LAN and 2 other customers. We have one ISP with a /27. I would like to have Public IP 1 for our LAN, Public IP 2 for VLAN2 and Public IP 3 for VLAN3.
Topology ASA5510 > Router > L2 Switch.
How do I configure the ASA to handle these requirements and also have the hosts use their current subnets to access the internet.
12 Replies 12
Jon Marshall
Kurt
Could you explain exactly what you want the ASA to do in terms of IP addresses. It is relatively easy to have 1 public IP per vlan to hide all the addresses behind when they go out to the Internet but it's not clear if you need to present internal servers on the vlans to the Internet so people can access them from outside.
Jon
Hi Jon,
Yes there are internal servers on the VLAN's that need to be accessed from the outside. For example On one VLAN several ports including 80 25 443 etc need to be forwarded to one server. It's a help desk system.
Those same ports are used on the native vlan as well.
Kurt
Sorry one more quick question. Do you want to just allocate
1 public IP per customer for both internal to external and external to internal
1 public per customer for external and 1 public per customer for internal - so for the external to internal access you would use port redirection ie. one IP address for multiple server(s)/port(s)
1 public for internal to external per customer
1 public per internal server you want to present.
If you could give the server details and how you want to allocate addresses should be able to provide config.
Jon
Here is what I have already tried in the past but it didn't work.
ASA relevent config
name 192.168.1.101 OOPS_Server
interface Ethernet0/0
nameif Outside
security-level 0
ip address x.x.x.110 255.255.255.240
object-group service OOPS_tcp tcp
description TCP ports forwarded to OOPS 192.168.1.101
port-object eq smtp
port-object eq www
port-object eq 439
port-object eq https
port-object eq 995
port-object eq 740
port-object eq 741
port-object eq 5900
port-object eq 4556
port-object eq 873
port-object range 53101 53109
access-list from-outside extended permit tcp any host x.x.x.102 object-group OOPS_tcp
static (inside,Outside) x.x.x.102 OOPS_Server netmask 255.255.255.255
route inside 192.168.1.0 255.255.255.0 10.1.10.2 <<< Address of Cisco Router which is directly connected to VLAN
The internal OOPS_Server also has to send alert emails out so it needs to be natted on the way out to .102. I'm not sure how to get that NAT to work.
Will this require another global (outside) address?
The router is an 1811W and will have a trunk link to the switch and I will configure the VLAN interface to be the default gateway of the internal VLAN subnet.
Can you tell me if I'm missing something here?
-Kurt
Kurt
Which bit didn't work ?
"The internal OOPS_Server also has to send alert emails out so it needs to be natted on the way out to .102. I'm not sure how to get that NAT to work."
No the statement
works both ways so any traffic leaving the OOPS_Server should be presented as x.x.x.102 when it goes out.
If you could detail which bits don't work from the above config. Also do you know which address the OOPS_Server is going out as ?
Finally can you post the rest of the config on the ASA or at least the rest of the NAT config as there may be a conflict within your NAT setup.
Jon
Hi Jon,
The part that didn't work was that when calling up the web page via a browser that points to *.102, I got timeouts and I didn't see the traffic hitting the interface. So I'm wondering how to get that to work.
I am trying to hit it via an internal network. 10.1.1.0/24. DNS says to connect via 72.54.2.102. It is currently behind it's own router but that router is an old linksys that is slowly dying and it works fine in this way.
Attached is the relative config for the ASA and the router.
Hi Jon,
Any more advice for me?
Kurt
My sincere apologies, i missed your update.
Just to clarify, what is the source IP address you are trying to connect to .102 from ?
Jon
both from the internet and internally from 10.1.1.x
Kurt
"The part that didn't work was that when calling up the web page via a browser that points to *.102, I got timeouts and I didn't see the traffic hitting the interface. So I'm wondering how to get that to work. "
What happens if you try and connect internally not using the public address but the private address.
Also when you try from the Internet does it work or not. I'm sure we can get this working i'm just not clear exactly which bits work, which don't and what you want.
Jon
to be honest, I'm not sure if it works from the internet or not as I wasn't able to test. But when I tried this last time, going directly to the site internally via it's public dns address of .102, it didn't work. I think it has something to do with the traffic going out the same interface it's trying to come back in on. It seems we need to set up hairpining which I'm not sure how to do.
Does my config look good so far for accessing the site externally?
-Kurt
Kurt
Your config for external access looks fine to me which is why i'm slightly confused.
I think if you are trying to access internally you do indeed need to setup hairpinning / DNS doctoring. I'm attaching a link to a doc that shows how to set that up -
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00807968d1.shtml
If there is anything else i can help with please come back as i don't feel i'm helping that much at the moment.
Jon
