Webcast-Catalyst9k
Multiple Routing Tables - Sup 720
Guys,
is this possible to do? If I want to have groups of vlans to have their own routing tables preventing the groups to route between eachother and push them to a default gateway of a firewall.
if so do you need any special hardware or software? Is an FWSM required?
Any good docs on this would be usefuly cant seem to find anything on it.
thanks
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Multiple Routing Tables - Sup 720
Hello Mick,
this is possible with sup720
you can use VRF lite or full featured MPLS VPN to have separate routing tables and subsets of interfaces
see
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/pfc3mpls.html#wp1047631
or
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/pfc3mpls.html#wp1047631
the difference is that in VRF lite no MPLS links are used and you need to provide dedicated logical links for each topology.
With MPLS this is not needed.
A FWSM is not required but it can completes the solution in some scenarios
Edit:
a design guide
http://www.cisco.com/en/US/docs/solutions/Enterprise/Network_Virtualization/PathIsol.html
Hope to help
Giuseppe
Hello Mick,
see
or
Edit:
a design guide
Hope to help
Giuseppe
Thanks Giuseppe helpful as always!
143
