Webcast-Catalyst9k
Multiple SSID on 877w
Does anyone know how to configure multiple SSID's on a 877w router? I've tried to do it by the manual but that doesn't work. I can't see the SSID coming up. One ssid comes up when I use the guest-mode command.
IOS: c870-advipservicesk9-mz.124-11.T1
bridge irb
interface range FastEthernet0 - 4
description *** IP-phone vlan 1/ data vlan 2 ***
switchport mode trunk
switchport voice vlan 2
auto qos voip trust
service-policy output AutoQoS-Policy-Trust
interface Dot11Radio0
no ip address
broadcast-key vlan 1 change 45
broadcast-key vlan 3 change 45
encryption vlan 1 mode ciphers tkip
encryption vlan 3 mode ciphers tkip
ssid Employees
vlan 1
authentication open
guest-mode
authentication key-management wpa
wpa-psk ascii 7 XXXXXXXXXXXXXXX
ssid Visitors
vlan 3
authentication open
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2412
station-role root
no dot11 extension aironet
no cdp enable
interface Dot11Radio0.1
description TCN-Employees
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.3
encapsulation dot1Q 3
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 spanning-disabled
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface Vlan2
description voice vlan
ip address 10.182.240.126 255.255.255.128
ip helper-address 10.30.52.1
interface Vlan3
no ip address
bridge-group 3
interface BVI1
description $ES_LAN$
ip address 10.182.240.254 255.255.255.192
interface BVI3
description visitors
ip address 10.182.240.190 255.255.255.192
bridge 1 protocol ieee
bridge 1 route ip
end
Thanx!
1 REPLY
Silver
Re: Multiple SSID on 877w
1) Router(config-if-ssid)# authentication
network-eap eap_methods
Above command is not there.
Look on below link: STEP-6
You can configue upto 10 SSID.
Q. How many Secure Set Identifiers (SSIDs) are configurable on the Cisco 870 Series and Cisco 850 Series?
A. Up to 10 SSIDs can be configured. All the SSIDs are active at the same time; that is, client devices can associate to the access point using any of the SSIDs.
Q. How many Multiple Broadband Secure Set Identifiers (MBSSIDs) are supported?
A. The Cisco 850 Series will support only one MBSSID, while the Cisco 870 Series will support up to two.
Look up on following link:
http://www.cisco.com/en/US/products/hw/routers/ps380/products_qanda_item0900aecd8028a982.shtml
Dharmesh Puroit
1055
