Multiple VLAN's on a single Interface
I have fiber unit that requires us to set Vlans that I connect to a Catalyst 4948 via fiber before connecting to my Cat6500 via Ethernet. I only have 4 connection from the Fiber unit to the Cat4948 but I have 100 Vlans to create. Currently I have Fa0/1 as below working. This Interface isn't passing the Vlan to the Cat6500.
interface FastEthernet0/1
switchport access vlan 64
switchport mode access
How to I allow Vlans 50-100 on this interface? I have created the Interface Vlans and added them to the GigE but when I did (see below) it didn't work. Am I missing something?
switchport
switchport trunk allowed vlan 50-100
switchport mode trunk
no cdp enable
** her is the gigE inter
interface GigabitEthernet0/1
switchport trunk allowed vlan 50-100 switchport mode trunk
Gabrielle
Re: Multiple VLAN's on a single Interface
Ports on Catalyst 6500 are layer 3. You must use the interface configuration command "switchport" in order to set as a layer 2 port.
I hope this helps.
Massimiliano.
My Cat 6500 are switchport but the Vlan is not being passed to the 6500 - they reside in a different Vlan on the 6500- The fiber device requires the use of certain Vlan numbers that I am trying to us on the 4948.
I am trying to use mulitple Vlans on the Fa0/1 port on the 4948 - the 6500 doesn't care what traffic it gets.
G
214
