Community Member
Multiple VLANs on L2 switch
Hello to all!
Can I create multiple VLANs in VTP transparent mode on Cat2950G?
Now I have no test device.
Please guide me!
Thanks.
haa33110@jnb.odn.ne.jp Unko
2 ACCEPTED SOLUTIONS
Community Member
Re: Multiple VLANs on L2 switch
You most certainly can!!
Create them through global config or VLAN database mode; I prefer global config, below is an example;
Router(config)#vlan 2,3,4,30
This will create VLANs 2,3,4 & 30.
Purple
Yes you can create multiples but you have to remember they will not be able to talk between them without a layer 3 device doing the routing.
Community Member
Community Member
Thanks for your kind support, Mr. Adam!
I had been in darkness about Cat2950.
(?・ω・`)
I had wrong idea that we can use vlan database command only on L3 switches.
Because my L2 devices are old Cat1900 and Cat2900.
Now something like fish scales fell from my eyes by your support!
Purple
Community Member
Thanks, General Grant!
I will take care about it!
172
