09-08-2008 09:24 AM - edited 03-06-2019 01:14 AM
I asked a question last week about using private vlans, and the answers I got seem to indicate this may not be the right way to do this.
Anyway, here's what I'm trying to do.
I have a port:
interface GigabitEthernet1/0/25
description DSLAM #2
switchport trunk allowed vlan 157,224,301,302,401,402
switchport mode trunk
switchport nonegotiate
end
I'd like to set this up so that vlans 157, 301, and 302 share the same subnet, and 224, 401, and 402 share an entirely different subnet.
Due to the nature of the DSLAM attached to the port, I have to have these on seperate VLANS.
Is private vlans the way to go? Is there any other way to do this?
thanks,
Ben
09-08-2008 09:51 AM
Hello Ben,
you can use IRB = integrated routing and bridging that on switch is also called inter-vlan bridging
bridge 1 protocol x
bridge 1 route ip
int bvi 1
ip address x.x.x.x 255.255.255.0
desc L3 interface for first vlan group
int vlan 157
no ip address
bridge-group 1
int vlan 301
no ip address
bridge-group 1
int vlan 302
bridge-group 1
the same can be done for the second group.
I did this inter-vlan bridging on a c3550, and it worked for non ipv4 traffic.
On a C6500 can work also for ipv4 traffic.
your device looks like to be a 3750 and is called fallback bridging:
here may be you can add a routed port for each bridge-group instead of a BVI.
Hope to help
Giuseppe
09-08-2008 10:15 AM
I've actually got a 3750G running Version 12.2(25)SEB4.
the first of these commands you gave me
bridge 1 protocol x
bridge 1 route ip
appear not to work. Is there anything I need to do prior to this, or is it something that I need either an IOS upgrade or a new product in order to do?
thanks,
-Ben
09-08-2008 10:43 AM
Hello Ben,
>> bridge 1 protocol x
this was a type error try ieee instead of x and follow the link for the details
Hope to help
Giuseppe
09-08-2008 11:51 AM
hrm. it looks like "bridge" isn't even a viable option. is there something I need to enable first?
-Ben
09-08-2008 11:57 AM
Hello Ben,
if this is not available
bridge bridge-group# protocol vlan-bridge
I think it is not supported in your current IOS release
Hope to help
Giuseppe
