Webcast-Catalyst9k
Multiple VTPs over a single fiber link
Is there a way to transport multple VTP domains over a single fiber link? We have 2 seperate locations we want to connect, which have muliple VTP domains.
Thanks in advance.
Re: Multiple VTPs over a single fiber link
This is not possible,but if u want to connect this two locations then what u can do is create a vlan on each location with same vlan ID and configure the ports which will be used for connecting in the vlan.
Mahmood
hi,
Two different vtp domain cannot communicate with each other,when a switch receive the vtp message from a different vtp domain it will discard the information,so i don't think its possible
Will MPLS work as a alternative solution?
You can connect multiple VTP Domains. Just as was said above, as long as VTP Domain A and VTP Domain B both have a shared VLAN say Vlan 16 you simply add a routing statement and you have inter VTP Domain communication.
194
