Community Member
N7K-F312FQ-25, Not FEX fabric capable?
Dear all,
Anyone struggled with the same problem:
According the specs the F3 line card should support FEX 2000 (in our case: NX2248PQ and NX2238TP)
While configuring an interface with "SWITCH MODE FEX-FABRIC", the system complains with:
DC1(config-if)# switchport mode fex-fabric
ERROR: Ethernet4/10: Configuration does not match the port capability.
Seems like the only interface on the F3 linecard that is able to support FEX fabric, is the BREAK-OUTed interface (4x 10GE) on a F3 interface.
Kind regards, Wim
Everyone's tags (3)
VIP Super Bronze
NX2238TP)You mean 2232?That
NX2238TP)
You mean 2232?
That is correct.  You need the Break-out cable to go from 40 to 10. Neither 2248 or 2232 support 40Gig
I use Panduit cable and they are pretty good:
http://www.panduit.com/wcs/Satellite?c=Page&childpagename=Panduit_Global%2FPG_Layout&cid=1345564328975&packedargs=locale%3Den_us%26prod_cat_id%3D3%26prod_id%3D3&pagename=PG_Wrapper
Community Member
Hi Reza,thanks for your
Hi Reza,
thanks for your feedback.
concerning fex I meant 2248TP, those are indeed connected using breakout cable from: N7K QSFP 40GE -> FEX 2248TP 4x 10GE.
But how to connect a 2248PQ, which has 4x 40GE as uplink to the N7K ? To do so, I need 4x 40GE interfaces at N7k running in FEX FABRIC switch mode.
The N7K is always complaining about port capability when I try to put an interface of the F3 linecard in fex mode.
The N7K is running 6.2(8)
VIP Super Bronze
Hi,Thanks for clarifying, now
Thanks for clarifying, now I understand the issue here. I have never worked with the 40Gig interfaces for the 7000 series (only 6000 series)
Can you try adding this command before the FEX fabric command and test again?  If not, I would open a ticket with Cisco to resolve this.
fabric-mode 40g
617
