04-16-2014 02:34 PM - edited 03-07-2019 07:07 PM
Hi guys,
Suddenly, one of the modules under 7K switch gave red alarm.
Following are the show module:
#show module
Mod Ports Module-Type Model Status
4 0 10 Gbps Ethernet Module powered-dn
Mod Power-Status Reason
4 powered-dn Unable to power up card (Power_OK not set)
Mod Sw Hw
1 6.2(6) 3.0
3 6.2(6) 1.0
Any common issue for that?
Regards.
04-16-2014 06:34 PM
Please try this.
1. Set on config t the diagnostic bootup level complete
2. Reseat module 4
3. show diagnostic result module 4
4. show module
If you still face the same issue after reseating it then RMA the module. Also check the available power on the switch and the minimum version required for the module to run fine.
04-16-2014 10:25 PM
There is no "Reseat module 4" command.
04-17-2014 06:58 AM
He means to pull the card out and then reseat it into the backplane..
