Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
name definition - Cat6500
Like PIX/ASA, is there a way to define name for a host. for e.g.
name 1.1.1.1 MYPC
1 ACCEPTED SOLUTION
Hall of Fame Super Bronze
Re: name definition - Cat6500
When I define ACLs using name definition in CAT6500 it is accepted. However, when I do 'show run' to view the ACL it shows the actual IPs of the hosts and not the names.
Is it possible to show host names in ACL of CAT6500 configuration.
Regards.
I'm afraid not.
When you enter the name, the device will automatically query the name to a DNS or internal host entry and transform it into an IP address format.
This is true in IOS on routers as well, not just Cat6k.
HTH,
__
Edison.
110
