NAT behaviour
on one of our border router we currently have NAT overload setup using one IP pool of 64 addresses. We have observed that the router use an IP address of the pool until all available ports are exausted. The it use the following one. Is possible change this behaviour?. Is possible that the NAT engine use all the IP address firstly, and after use the ports to each NAT entry?.
1 REPLY
Hall of Fame Super Silver
Re: NAT behaviour
Hello Antonio,
I've given a look at 12.4 ip addressing services command reference but I didn't find any option.
You can try the following:
divide your NAT pool in two pools
first pool is used first and without the overload option
(appears before in running config)
second pool is listed after and has the overload option.
But this reduces the number of possible concurrent TCP sessions to the internet
So I would keep the current configuration.
From ip nat translations you can track what an internal user is doing
Hope to help
Giuseppe
114
