NAT Cisco 2901
I am attempting to configure a Cisco 2901 router using IOS 15 to   properly perform NAT/PAT translation between LAN and the internet   connection.
My Configuration:
interface GigabitEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly
no ip route-cache
duplex auto
speed auto
no cdp enable
no mop enabled
interface ISM0/0
no ip address
no ip route-cache
shutdown
service-module fail-open
no cdp enable
hold-queue 60 out
interface ISM0/1
no ip address
no ip route-cache
shutdown
no cdp enable
interface GigabitEthernet0/1
ip address 10.1.1.1 255.255.255.0
ip nat inside
no ip route-cache
duplex auto
speed auto
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
access-list 1 permit 10.1.1.0 0.0.0.255
But Nat no work
Any ideas?
28 Replies 28
Besides I do not know what kind of internet access do you have , using private IPs ( 192.168.0/24 ) you have a little config issue :
no ip routing
no ip cef
Enable routing and cef :
conf t
ip routing
ip cef
end
wr mem
Dan
you are right! I have not seen it in the second configuration posted. It is most likely causing problems.
Best regards,
Jan
conf t
ip routing
ip cef
end
wr mem
and nothing
Jerson Júnior
I do not know what is happening, I have a Cisco 3640 with NAT Running!
Jerson Júnior
Hi ,
please post :
ping 8.8.8.8
show ip route
show ip inter brie
Dan
ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 24/28/44 ms
show ip route
Default gateway is 192.168.0.1
Host               Gateway           Last Use    Total Uses  Interface
ICMP redirect cache is empty
show ip inter brie
Interface                  IP-Address      OK? Method Status                Protocol
Embedded-Service-Engine0/0 unassigned      YES NVRAM  administratively down down
GigabitEthernet0/0         192.168.0.128   YES DHCP   up                    up
GigabitEthernet0/1         10.1.1.1        YES NVRAM  up                    up
Serial0/0/0                unassigned      YES NVRAM  administratively down down
NVI0                       unassigned      YES unset  administratively down down
IP routing is not enabled !
Enable ip routing
conf t
ip routing
end
After that , please paste show ip route
Dan
ip routing enable but now ping to external not work
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
S*    0.0.0.0/0 is directly connected, GigabitEthernet0/0
      192.168.0.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.0.0/24 is directly connected, GigabitEthernet0/0
L        192.168.0.128/32 is directly connected, GigabitEthernet0/0
That's ok.
You should change the default route
conf t
no ip route 0.0.0.0 0.0.0.0 Gi0/0
ip route 0.0.0.0 0.0.0.0 192.168.0.1
end
Try to access the internet. Tell me the result.
Dan
Nothing
I have a 3640 an NAT works with this configuration:
interface Ethernet0/0
ip address 10.1.1.253 255.255.255.0
ip nat inside
half-duplex
interface Ethernet1/0
no ip address
shutdown
half-duplex
interface FastEthernet2/0
description ### Internet GVT ###
ip address dhcp
ip nat outside
duplex auto
speed auto
ip default-gateway 192.168.1.1
ip nat inside source list 7 interface FastEthernet2/0 overload
ip nat inside source list 101 interface Ethernet0/0 overload
ip nat inside source static 10.1.1.253 192.168.1.4
ip nat inside source static tcp 10.1.1.253 80 192.168.1.2 80 extendable
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.1
no ip http server
access-list 7 permit 10.1.1.0 0.0.0.255
Please paste "show ip route"  from your Cisco 2901
Dan
Hi Everyone
Nat Works Now
Configuration:
ip address 192.168.1.4 255.255.255.0
ip nat outside
no ip virtual-reassembly in
duplex auto
speed auto
no cdp enable
no mop enabled
ip address 10.1.1.254 255.255.255.0
ip nat inside
duplex auto
speed auto
no cdp enable
interface Serial0/0/0
no ip address
shutdown
no fair-queue
clock rate 2000000
no ip http server
ip nat inside source list 101 interface GigabitEthernet0/1 overload
ip nat inside source static 10.1.1.254 192.168.1.4
Which was the solution ?
Dan
I think the solution was:
