NAT in Transition
3640 router version 12.3
We have most of our machines on a class C network. We have a DMZ setup with static NAT addresses. We are running low on the class C network IP addresses so would like to transition to NAT overload (PAT).
The commands I am using are:
ip nat pool ptinat 198.17.220.118 198.17.220.118 netmask 255.255.255.0
ip nat inside source list 20 pool ptinat overload
access-list 20 permit 172.28.0.0 0.0.255.255
I also put the following on the interface FastEthernet0/0
ip address 198.17.220.118 255.255.255.0 secondary
Once I have done this the 198.17.220.0 and the 172.28.0.0 networks cannot talk to each other.
Any ideas?
Re: NAT in Transition
the 198.17.220.0 and the 172.28.0.0 networks cannot talk to each other because you did PAT.
Only hosts from 172.28.0.0 can have an access to hosts in 198.17.220.0.
I am logged into the 172.28.0.0 host.
If I ping 198.17.220.0 host it is successful
If I traceroute 198.17.220.0 host it is succesfull
If I ssh to 198.17.220.0 host, it comes back with:
debug1: Connecting to 198.17.220.131 [198.17.220.131] port 22.
debug1: Connection established.
debug1: identity file /root/.ssh/identity type -1
debug1: identity file /root/.ssh/id_rsa type -1
debug1: identity file /root/.ssh/id_dsa type -1
ssh_exchange_identification: read: Connection reset by peer
If I turn NAT off, I can this same ssh will be successful.
I am grateful for any help you can give me.
Thank you.
Could you show all parts of your config related to NAT/PAT?
I am a bit nervous about putting too much of the config out on the network.Does this help at all?
ip address 198.17.x.x 255.255.255.0
ip broadcast-address 198.17.220.255
ip nat outside
interface FastEthernet3/1
description PTI TESTING NAT
ip address 172.28.0.100 255.255.0.0
ip broadcast-address 172.28.0.255
ip nat inside
remove this line from the config
and try again
Sorry to say it did not make any difference to have the secondary interface removed.
150
