Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Nat IP-nat directed-broadcast to another Nat IP-nat directed-broadcast
Hello
Do you know if it possible to nat an ip directed broadcast such as (10.253.123.255 --> 10.253.120.0/30) to another directed broadcast (10.10.10.255 --> 10.10.10.0/24)
i test nat a ip directed-broadcast to an ip address and it's work perfectly
Synthax which work but not that i want:
ip nat pool poule 10.10.10.252 10.10.10.252 netmask 255.255.255.0 type rotary
ip nat inside destination list 11 pool poule
access-list 11 permit 10.253.123.255
Synthax which not work that i want:
ip nat pool poule 10.10.10.255 10.10.10.255 netmask 255.255.255.0 type rotary
This is for WoL over 802.1X with Vlan Assignement problem because WoL use ip directed-broadcast over udp port 0.
if you have any idea
thanks
1 REPLY
Silver
Re: Nat IP-nat directed-broadcast to another Nat IP-nat directed
If the server is sending out WOL packets as directed broadcast (10.253.123.255), then "ip directed-broadcast" on the source vlan interface needs to be enabled and "ip forward-protocol udp " has to be configured for the udp port# the server is sending these WOL packet to, so that the router will forward these udp packets in addition to the default 8 udp ports (e.g. bootp, dns..etc).
311
