12-18-2006 04:27 AM - edited 03-05-2019 01:22 PM
Folks I am brand new at this.
I have a 2600 (with a T1, 1 Fast ethernet,1 serial interface)connecting to the internet port on my RR modem. First, how do configure NAT and DHCP server on the router. Second, how do I connect 2924 switch on it for my network.
12-18-2006 04:46 AM
Hi Zek,
find the DHCP & NAT configuration below for ur Cisco 2600 Router.
ip dhcp pool TEST
network 192.168.1.0 255.255.255.0
dns-server
default-router 192.168.1.1
domain-name abc.com
ip dhcp-server 192.168.1.1
interface Serial0
description "Connected to Internet"
ip address x.x.x.x 255.255.255.252
ip nat outside
interface FastEthernet0
description "Connected to LAN"
ip nat inside
ip nat translation timeout 3600
ip nat pool TEST 1.1.1.10 1.1.1.15 netmask 255.255.255.240
ip nat inside source list 1 pool TEST overload
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0
no ip http server
access-list 1 permit 192.168.1.0 0.0.0.255
1.1.1.x is the list of public IP address given by ur ISP.
hope this helps.
rate this post.
12-18-2006 04:47 AM
From your ISP are u getting any public ip block which you can make use for the NAT pool ?
If not then you need to go on for PAT doing overload onto your serial interface which gets you connected to you SP.
regds
12-18-2006 04:54 AM
you have to connect switch to fast ethernet interface of router and T1 terminated on serial interface.
I'm assuming that you are having public IP from ISP which will be configured on T1 interface of your router and you have a private subnet which will be used for internal LAN. I'm taking 192.168.0.0/24 subnet for your LAN.
NAT config on router will look like this:
description *** Connected to LAN Switch ****
ip address 192.168.0.1 255.255.255.0
ip nat inside
interface Serial0
description *** Connected to ISP Router ****
ip address x.x.x.x x.x.x.x
ip nat outside
ip route 0.0.0.0 0.0.0.0 s0
access-list 7 192.168.0.0 0.0.0.255
ip nat inside source list 7 interface serial 0 overload
check this URL to get more information on NAT.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e77.shtml
hope to help ... rate if it does ....
12-18-2006 06:28 AM
Thank you all.
The T1 int. connects to another T1 int. on another 2600b in a WAN serial simulation. 2600a has only one fast ethernet int., which is connecting to RR modem. Configuring NAT/DHCP server is my first objective, the other one is connecting a 2924 switch off the router. Possible?
12-18-2006 06:39 AM
for connecting switch to this router, you should have atleast one free ethernet/ fast ethernet port on this router which I think you don't have, so I don't think it is possible to connect switch to this router.
you can configure NAT/DHCP on this router as mentioned in previous posts, But I'm not sure where you are going to use these services because I guess you will configure NAT/DHCP for the clients which will be connected to your network through switch.
so, your first objective should be to connect a switch to this router and then configure NAT/DHCP on it.
