NAT on a Cisco 831
I have a Cisco 831
version 12.4
I setup NAT on my cisco and it is working fine but with one issue.
I can't pull up internal hosted sites by public IP only the Private IP.
Is there a way NAT can be setup so pages can be accessed internal and external on the cisco?
I'm sure it can be done because I don't have that problem on a cheap Linksys router.
Currently NAT Config:
interface Ethernet0
description LAN
ip address 192.168.4.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Ethernet1
description WAN
ip address 74.143.x.x 255.255.255.248 secondary
ip nat outside
duplex auto
ip nat inside source list 1 interface Ethernet1 overload
ip nat inside source static tcp 192.168.4.100 53 74.143.x.x 53 extendable
ip nat inside source static udp 192.168.4.100 53 74.143.x.x 53 extendable
ip nat inside source static tcp 192.168.4.100 80 74.143.x.x 80 extendable
access-list 1 permit 192.168.4.0 0.0.0.255
Re: NAT on a Cisco 831
Hello ,
the nat is ok :
root@magnum:~# host boydsinternet.com
boydsinternet.com has address 74.143.14.20
boydsinternet.com mail is handled by 0 mail.boydsinternet.com.
root@magnum:~#
root@magnum:~#
root@magnum:~#
root@magnum:~#
root@magnum:~# telnet 74.143.14.20 80
Trying 74.143.14.20...
Connected to 74.143.14.20.
Escape character is '^]'.
GET /
Bad Request (Invalid Hostname)
Connection closed by foreign host.
root@magnum:~#
You got a http daemon problem (probably an IIS ).
No I am 100% positive it is not the server.
It is running Web/ftp/http/mail/mysql/etc.
Maybe I worded my post wrong
I have no problems at all with someone accessing me from the internet.
Put in boydsinternet.com in your brower it will come right up.
I can get to boydsinternet.com from any network and it will come right up execpt were the server is located
another example
Like if you do the following command "telnet 74.143.14.20 25" (My mailenable server promopt will come right up for anyone but me because I am doing it at the server it'self)
I know it is something with the NAT translations. I think I need 1-1 NAT maybe
Just saying that the server is ok and is running 'n' services , its not a technical explanation.
I think that the IIS is configured with virtual hosts ( based on domains ) and you have no default site.
You should think, if you are using the domain everything is ok and if you are using the IP you got an error , at least you can check IIS logs and/or search for that error on the internet.
My bottom line is that the NAT is ok. :)
Thank you
I know NAT is ok and configured correctly
I am mainly looking for another way to setup NAT
I toke off my back-up linux server (74.143.14.21) from the Cisco 831
Put it on a cheap linksys router I had laying around and setup NAT on it.
I can now pull pages by public IP and private IP from the local server.
I put it back on the cisco 831 and now I can only pull the page by private
Any Idea's
Surely I am not the only one that has seen this issue?
1162
