NAT on C2911 ISR complicated...
I am trying to design a solution to my problem with little results.
My goal is to have my C2911 router that is running BGP to my ISP successfully NAT an inside network that is attached to the C2911. I am not entirely sure this is possible, or even the best solution.
Network design is a dual-tier FW with a DMZ in between. In this DMZ there are web servers serviced by software load-balancers. I am trying to prevent having to use the real Virtual IPs for the LBs so I was hoping to implement an outbound NAT in between my inside DMZ network and my edge BGP router (C2911)
I believe this is all the pertinent information:
interface GigabitEthernet0/0
description inside DMZ network /24
ip address 10.100.3.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description BGP peer to ISP /30
ip address 10.200.0.1 255.255.255.252
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/2
description public IP block /24
ip address 10.250.0.2 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
standby 10 ip 10.250.0.1
standby 10 priority 110
standby 10 preempt
standby 10 track 1 decrement 20
duplex auto
speed auto
no mop enabled
router bgp 64000
bgp log-neighbor-changes
neighbor 10.200.0.2 remote-as 1111
neighbor 10.200.0.2 description <blah>
neighbor 10.200.0.2 password 7 <hash>
neighbor 10.200.0.2 timers 30 90 30
neighbor 10.250.0.3 remote-as 64000
neighbor 10.250.0.3 description X-connect to Secondary Router
neighbor 10.250.0.3 password 7 <hash>
address-family ipv4
  network 10.250.0.0
  neighbor 10.200.0.2 activate
  neighbor 10.200.0.2 soft-reconfiguration inbound
  neighbor 10.250.0.3 activate
exit-address-family
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat pool dmz16_pat 10.250.0.226 10.250.0.226 netmask 255.255.255.255
ip nat inside source list 1 pool dmz16_pat overload
ip nat inside source static 10.100.3.200 10.250.0.200
ip nat inside source static 10.100.3.201 10.250.0.201
ip nat inside source static 10.100.3.206 10.250.0.206
ip nat inside source static 10.100.3.207 10.250.0.207
ip nat inside source static 10.100.3.208 10.250.0.208
ip nat inside source static 10.100.3.209 10.250.0.209
ip nat inside source static 10.100.3.210 10.250.0.210
ip nat inside source static 10.100.3.211 10.250.0.211
ip nat inside source static 10.100.3.217 10.250.0.217
ip nat inside source static 10.100.3.218 10.250.0.218
ip nat inside source static 10.100.3.219 10.250.0.219
ip nat inside source static 10.100.3.220 10.250.0.220
ip nat inside source static 10.100.3.223 10.250.0.223
ip nat inside source static 10.100.3.224 10.250.0.224
ip nat inside source static 10.100.3.232 10.250.0.232
ip nat inside source static 10.100.3.233 10.250.0.233
ip nat inside source static 10.100.3.234 10.250.0.234
ip nat inside source static 10.100.3.235 10.250.0.235
ip nat inside source static 10.100.3.236 10.250.0.236
ip nat inside source static 10.100.3.237 10.250.0.237
ip nat inside source static 10.100.3.238 10.250.0.238
ip nat inside source static 10.100.3.239 10.250.0.239
ip nat inside source static 10.100.3.240 10.250.0.240
ip route 10.250.0.0 255.255.255.0 Null0
access-list 1 permit 10.100.3.0 0.0.0.255
access-list 101 <omit>
Thanks in advance for anyone offering up any thoughts!
Cheers!
Everyone's tags (2)
582
