08-25-2009 12:34 PM - edited 03-06-2019 07:25 AM
Hello Cisco Pros,
I have a router with a single internet-routable IP address, and an ipsec VPN connection via a Tunnel0 interface. I'd like to setup NAT through the router such that traffic arriving from anywhere on the Internet on port 80 goes to a different host across the ipsec VPN on port 8080. I've tried a lot of different configuration examples, and can't seem to get it right. Is this at all possible?
I've tried:
interface Tunnel0
ip address 192.168.1.1 255.255.255.252
ip nat inside
interface FastEthernet 1/0
ip address 12.34.56.78 255.255.255.252
ip nat outside
ip nat inside source static tcp 192.168.1.2 8080 12.34.56.78 80
(where 192.168.1.2 is a host across the VPN tunnel, and 12.34.56.78 is the external IP address of F1/0)
Nothing I'm trying is working. Thanks for your suggestions!
08-25-2009 01:09 PM
Could you break down your issue using IP addresses? From which interface packets enter and exit?
08-25-2009 01:32 PM
Sure, packets will enter through the F1/0 interface, and will be destined for 12.34.56.78 (or a similar IP if I cannot use F1/0's address). I'd then like to NAT the traffic using Tunnel0's IP address.
So It works like this:
Internet User --> 12.34.56.78:8080 --> goes through vpn to 192.168.1.2:80.
Hope this makes sense.
08-25-2009 03:10 PM
What is the source address of tunnel0? Are you are sourcing tunnel from f1/0?
08-26-2009 05:41 AM
Yes, I am sourcing it from F1/0:
I can change where traffic is sourced from, if necessary. I just need Internet users to be NAT'ted over the IPsec VPN tunnel somehow.... Thanks!
interface Tunnel0
ip nat inside
ip virtual-reassembly
tunnel source 12.34.56.78
tunnel destination 23.45.67.89
tunnel mode ipsec ipv4
tunnel protection ipsec profile P1
08-26-2009 06:02 AM
I think that's the reason why it's not working right now. Here 'ip nat inside' and 'ip nat outside' are virtually present on the same physical interface f1/0.
Is it possible for you to use Tunnel source as interface other than f1/0?
08-26-2009 06:13 AM
Sure, I also have a F1/1 interface I could use. Let me try that and see if it fixes anything. Thanks for your replies!
08-27-2009 07:09 AM
I have a host on the other side of the VPN tunnel. I do not want this host to see the true source of the outside global host. No matter how I set up NAT, the outside global's source IP always comes through to my inside local host.
How (using NAT), can I have traffic from an Internet host flow through the router, so that my inside host only sees an IP request coming from the router?
Thanks!
